Re: My W6 won't run
Posted by trutherf on December 25, 2008 at 19:14:52 from (72.160.102.97):
In Reply to: Re: My W6 won't run posted by KEB1 on December 25, 2008 at 18:25:25:
I did pull the valve cover off. All EIGHT valves remain motionless when pushing the start button or turning the motor manually. I think there is no compression, but won't know for sure until I can get someone else to turn the motor while I put my thumb over the hole.
I pulled the plugs out, re-hooked the plug wires to them and watched the spark as the motor turned over. There was a bright blue spark that actually shocked me pretty good once.
Is the distributor rotor supposed to turn in one fluid motion, or almost come to a stop at each point? I pulled the cap off and watched the rotor as the starter was turning and the rotor almost stops where each point would be. It sort of creates a ticking noise.
