Re: 856 farmall
Posted by Hugh MacKay on December 25, 2008 at 19:21:39 from (209.226.247.30):
In Reply to: 856 farmall posted by muncy on December 25, 2008 at 12:24:06:
Muncy: Don't let them kid you, that 856 with a gasser is little more than a parts tractor. No one is going to pay you much for it. I don't care how low production numbers were.
I agree the 407 diesel engine will be hard to find. Don't go 282, not enough power for that chassis. 282 was a great engine running a 2,000 rpm max in the 560 and 656. Once it was turned up to 2,400 for 706 or 660 it was not noted for longevity.
There are hundreds of used DT360 or DT466 truck engines around in good condition. It will cost you $8,000 to $10,000. by the time you have it installed in 856 and set at a reasonble hp. Next question, is your 856 chassis in good enough condition to be worth spending those kinds of dollars. A lot of gassers are, no one could afford to farm with them since 1983.
Yes the fuel efficiency is there. I farmed with gassers many years ago. When we got 560 and 656 diesels, first thing we noticed, engine maintainence was nothing more than oil and filters for 10,000 hours. Fuel consumption was 1/3 the gallons for the same horse power. Diesel would be a bargain if it were twice the cost of gas. Finally diesel will give much steadier hp on heavy work. I pulled a 5x16 semi-mount plow with my 656 diesel. A friend had a 656 gasser, told me he had trouble with 4x14 plow in some conditions.
I had a Farmall 300 gas from new, always pulled 3x16 trailer plow. I acquired a 504 gasser with farmland. The vendor told me not to keep it any longer than I had to. I told him 504 was 10 more hp than 300. He said, " one has to be a dreamer to believe that, take the tractor to the field and try it." I did and I hooked it to that 3x16 plow, the 300 pulled so faithfully. One hour later I was back to plowing with old 300, and the 504 got traded off on a new 1066. Plain and simple the gas engines IH built after 1958 were crap. Possible exception were Cub and 140.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
