Not a good idea. Just like you should never fill a hot eninge with cold water unless it is running or you can/will crack the block. So filling an engine with hot water and its cold can/will crack a block. Now if you could say hook up an water heater to it and start with cold water and then turn on the water heater so it heated up the engine slowly yes that could work. I have tried to figure out how to do that but so far the problem is how to fill and keep things as they need to be and be safe and hot enough to do any good. I.E. you would need to have the water up to around 200 plus degrees to do much good
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
