Re: clutch pilot shaft for C Farmall
Posted by 504-2 on December 25, 2008 at 21:04:41 from (216.145.144.254):
In Reply to: clutch pilot shaft for C Farmall posted by thumbanger on December 23, 2008 at 06:47:40:
Take an old broom handle and grind down the end on a bench grinder,spinning the handle as you go, grind to fit the bearing, then grind to fit the clutch.It is fast cheap works fine. Dowel rod will work too.
