Re: Just bought an H and I see I have antifreeze in the oil
Posted by dave westlund on December 26, 2008 at 03:26:20 from (69.46.194.235):
In Reply to: Re: Just bought an H and I see I have antifreeze in the oil posted by Nebraska kirk on December 25, 2008 at 21:22:03:
Would it be best to pull the oil pan off first then the head to find the source of the leak?
If the block is cracked, would it be ez to see?
Again, I appreciate the help.
Thanks
Dave
