Re: Just bought an H and I see I have antifreeze in the oil
Posted by Central Illinois on December 26, 2008 at 07:52:24 from (99.196.11.55):
In Reply to: Just bought an H and I see I have antifreeze in the oil posted by dave westlund on December 25, 2008 at 17:24:08:
Pull the pan. Don't pull the head just yet. Leave everything but the pan alone. Let it set and have a look to determine where it is coming from. If you have access to a radiator pressure tester use it. Pump it up to around 10 lbs. Let it set. Start looking. Once you have an idea of where the leak is coming from then start the tear down. I have cheated in the past and used K&W block sealer. Five years later it is still working.
