Re: I.H. 300 utility steering box problem
Posted by CNKS on December 26, 2008 at 08:31:12 from (216.144.104.128):
In Reply to: Re: I.H. 300 utility steering box problem posted by Mark Peters on December 26, 2008 at 07:16:22:
On my 460 Hi Utility, the power steering is separate from the manual gear box. I have not compared part numbers, but I think the same manual unit would be used power or not. The factory power unit is on/in the steering column above the manual unit. On the 460 the pump is attached to the hydraulic (fast hitch,etc) pump in the belly of the tractor -- don't know about the 300. I don't know how Jackson does it, though. Anyway, unless Jackson is doing some sort of hydrostatic conversion, you will likely need an original steering unit.
