Re: 560 gas hydro hose
Posted by El Toro on December 26, 2008 at 12:15:58 from (205.188.116.73):
In Reply to: 560 gas hydro hose posted by 1206fan on December 26, 2008 at 10:42:34:
If the hose is still good at the 3-bolt flange your local hydraulic shop may be able to cut the hose out from the flange and install a new section
of hydraulic hose with crimp on fittings and install the correct fitting on the other end. Whether it's pipe thread or a tube swivel nut.
They would need to see the hose.
If this isn't possible call steelwheelranch at 785-548-7437 to see if they have a good used hose. Hal
