Re: farmall 460 hyd. Question
Posted by Hugh MacKay on December 26, 2008 at 13:15:41 from (209.226.247.154):
In Reply to: farmall 460 hyd. Question posted by L Paul on December 26, 2008 at 12:50:03:
L Paul: If it works sometimes, very likely not the pump. I suspect it may be the draft control linkage between hitch lift cylinder and the control valve.
It will not hurt anything to run tractor with TA out. The damage that will happen has been done, just run it with lever forward.
