If you haven'd done it already, try draining the carburator bowl and cleaning and draining the sediment bowl. Blow out the gas line and let a generous amount flow through before you put it back on. (Be sure to catch the waste you know to protect the environment.) Use some of that gasoline addative that clears moisture and gel from the carburator (for old gasoline). In the old days we just had to drain the tank and put in new gasoline. Too expensive to do that now. As posted by others you still may have a leak in the intake gasket or a rust hole in the intake. The carburator gasket itself may have gone bad. Remember it has been over 10-years since you did a rebuild on that carburator. I would put up the torch however before you hurt yourself or burn down your shed. larry m
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
