Re: No one is going to believe this!
Posted by rumplestiltskin on December 26, 2008 at 17:43:53 from (96.12.151.126):
In Reply to: Re: No one is going to believe this! posted by Farrview on December 26, 2008 at 15:55:40:
Is it possible your storage tank has some water in it? If your M got the good stuff from the top of the tank (like a 5-gallon can, for example) and your other tractor got the water from the bottom of the tank, that would make a ton of difference.
If it"s a small enough tank that you can empty it into a clear container (or maybe take a one-gallon sample), it will be easy to see a dividing line between the gasoline and any water that may be present.
Mark W. in MI
