Re: jump starter
Posted by old on December 26, 2008 at 19:46:03 from (4.245.4.250):
In Reply to: jump starter posted by cris on December 26, 2008 at 19:22:05:
Reason they say hook to a metal surface instead of right to the battery is to keep from having a spark at the battery. A spark at the battery can/will cause the battery to explode and that is a bad thing. As far as jumping a 6 volt system with it if its 12 volts the only way to do that is hook it right to the starter post NEVER so as to put the 12 volts across the 6 volt battery or you could blow the 6 volt battery up
