Most freeze the liners and warm the block with a heat lamp or other modest source to just above room temp. The cylinder cast bores are often select fit meaning they are not all the same. Each should have a letter stamped near the rim of the sleeve on the deck. The letters are from A to D with A being smallest select fit. If you have a C or D hole, it might be big enough to not have a good fit with the sleeeves supplied in the kit. The answer might be to have one sleeve made (LA Sleeve, or other good source) or find a sleeve that is larger in a kit. Selecting between the variability in the sleeves supplied can also do it. Any sleeve that slides in 3/4 of the way without heating or cooling, will be OK. if it pushes in with hand pressure W/O freezing, I would not do it. The rims fracture and the sleeve sucks into the bottom end. Very not good. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
