Re: Stuck BN's - Update #1
Posted by LMack on December 27, 2008 at 15:28:06 from (66.156.32.45):
In Reply to: Stuck BN's - Update #1 posted by Clarkbug on December 27, 2008 at 14:27:03:
Did it have any push rods? Without push rods all the valves would be closed. Sounds like someone has been inside that engine before and gave up. I think you had better start shopping for sleeves and pistons as well. You do not have to pull the engine to do an overhaul. Take the rods loose from the crank and you can drive the pistons out.
