mkirsch: The others are right about those studs, fine thread to the nut and coarse thread going into casting.
BE CAREFUL here the hole closest the axle, one each side has a bottom, part of the casting. If you use too long bolt it will break out that bottom, and the chunk of casting falls into bull gear sump. This applies both front and rear of axle on SA final drives. Please don't ask how I know, it happened 50 years ago.
I suspect the fast hitch pull bar is shorter on Cub than SA-140. You may have to extend that. This is why I recommended using the drawbar in my earlier post. Doing it as I suggested in my earlier post requires a shorter pull bar. I also think your going to encounter problems trying to bolt the Cub hitch bail to SA final drives.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
