Re: fasthitch inserts for three point
Posted by Al L. in Wisc. on December 27, 2008 at 15:55:52 from (207.190.67.77):
In Reply to: fasthitch inserts for three point posted by IndianaRed on December 26, 2008 at 13:57:39:
third party image[img]
Randy, I'm having trouble getting a photo to post and crashed my Mozilla - ??? anyway, if this works this is the adapter arm I purchased from IH dealer - $192 per set. Back up to implement and place the hitch pins into slots. If you have a narrower implement, you can use longer hitch pins. These arms/sockets on my Farmall 340 measure 29" outside to outside. This beats putting arms with ball sockets onto hitch pins then wrangling to get the arms into fasthitch sockets; I used twine to hold up arms and backed into them - not easy. Good luck and post back your results so maybe it will help others.
This post was edited by Al L. in Wisc. at 16:01:50 12/27/08.
