Re: rear wheel bolt pattern
Posted by Janicholson on December 27, 2008 at 16:56:51 from (68.112.156.69):
In Reply to: rear wheel bolt pattern posted by rhettcale on December 27, 2008 at 16:32:21:
Use a compass and make circles at just about the correct size. Put the closest one in the center of the bolt pattern. and measure the distance to the center of the holes from the edge of that centered circle. add two of that distance to the diameter of the circle (pie tins and such make good circles also) and that is the bolt circle diameter. It will be in no less than 1/4 " increments, but likely 1/5" closest to the measured size. Then count the bolts. (also if an even number going across to center will give diameter) Wheels are given (in many cases) as 8 bolts on 8-1/2" circle. Good luck, JimN
