Re: Size of cylinder for tilting the bucket on a loader?
Posted by old on December 27, 2008 at 17:27:05 from (4.245.0.22):
In Reply to: Size of cylinder for tilting the bucket on a loader? posted by unioncreek on December 27, 2008 at 16:34:07:
You will be better off to use 2 instead of one. But if you do use 1 use the bigger one because you could end up not having enough lift to do the job other wise and even then with just one your more likely to bend the bucket in ways that you will not like BTDT and found 2 is better then one by far
