Re: Thoughts on a 560 Farmall
Posted by Colorado Curt on December 27, 2008 at 19:28:28 from (67.173.243.232):
In Reply to: Thoughts on a 560 Farmall posted by biggerred on December 27, 2008 at 18:24:13:
I have a 560D and really like it. They can be a bugger to start, but if you have good glow plugs and enough patience to let them do their job, it will start. Another big factor to get any diesel to start is a good battery and good connections. You need to spin the engine fast enough to build the compression. I use mine for hay work. They are really good on fuel.
