Posted by Janicholson on December 27, 2008 at 22:02:01 from (64.83.200.187):
In Reply to: More '48 H questions posted by Chad504 on December 27, 2008 at 19:32:57:
There are pictures in the archives of Hs with the original bracket turned upside down, and a length of all thread used with a pipe spacer to anchor the pivot. The light sw is no problem. just remove the wire that went to the F terminal on the gen and there you are. Off Off dim bright going clockwise from full left. Two big pipe wrenches on opposite sides with cheaters as needed, heat and force. JimN Drill out the pin until nearrly gon, then drive it out with a pin punch of the same size. Put a new pin in the hole made from a grade 8 bolt, cut to the correct length.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
