Re: Allan in NE
Posted by Bob Kerr on December 28, 2008 at 00:53:26 from (63.134.174.158):
In Reply to: Allan in NE posted by Michael Soldan on December 27, 2008 at 08:25:46:
If a thermostat and or water pump have been replaced and some one used "Blue Glue" or some kind of silicone sealer, it may just be clogged with silicone chunks. Unhook it and backflush it with a garden hose and see what comes out. Had several I worked on where a bunch of " blue fishing worms" came out and fixed the problem. Also check the water control valve if it has A/C and make sure it is working. Sometimes a vacuum hose can come off under the dash and not let the valve open. Some open with vac and some close with vac. Not sure which type you have but not hard to figure out.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
