If you jump it with one cable attached direct to the starter terminal/stud (attach it first) then jump the other lead to a good clean frame ground close to the starter, THAT ENERGIZES AND DRIVES THE STARTER ONLY (provided starter switch isnt engaged) AND WILL NOT BACKFEED 12 VOLTS UP TO THE BATTERY (OLD, AS USUAL, IS CORRECT) which could cause it to blow up so thats how I suggest it be jump started. So long as the battery has enough energy to provide a spark (unless its a mag which dont need battery energy) and all else is correct, she ought to start.
THE WORST AND MOST DANGEROUS way to jump would be by attaching the cables right at the battery top cuz thats where explosive gasses may be exiting and you will create a spark when the last cable is atatched. Thats why they tell you to make the last jump connection at frame ground somewhere far away from the battery
MAKE SURE ITS OUT OF GEAR DUHHHHHHHHHH
JUMP AT THE CORRECT POLARITY + to + and - to -
Im NOT a fan of the 8 volt band aid approach, I suggest EITHER use 00 gauge battery n starter n ground cables and the biggest heaviest highest rated 6 volt battery that will fit in place or else convert to the standard 12 volt system.
Depending on if its a Cutout Relay or a Voltage Regulator etc the tractor 6 volt genny can still charge an 8 volt battery if all is correct although it may not set the world on fire as far as the charge rate.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
