Re: 154 Cub Low Boy: not much power to pull its mower
Posted by the tractor vet on December 28, 2008 at 07:15:38 from (76.212.238.50):
In Reply to: 154 Cub Low Boy: not much power to pull its mower posted by johnlpleasantview on December 27, 2008 at 16:42:15:
With only 90 lbs comp. she will not have much power as she is getting tired , should be up around 120 . Now if ya rebuild then use the 184 pistons and head and the carb. . One thing to check is the centrifugal asv. if this is not working correctly or the timing is off she will be lazy if it is retarded and if to far advanced then she will be fighting herself tryen to get the piston over the top and this will kill power
