Dump the oil and check it for metal shavings. You will have some particles in the oil which is normal for a new engine to have. However you should not have shavings. If you find metal shaving then you know you have an issue and need to drop the pan for an inspection on the parts.
Myself I would change the oil and retorque the head. Then run the engine another twenty minutes without messing with it. Change the oil after that twenty minute run and see what you have and make your final adjustments. Pay good attention to how the engine sounds, oil pressure and temperature while you a running her. If you bought a sleeve and piston set and kept the pistons and sleeves matched up with themselves I would think you will be fine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
