Re: Bearings on MV
Posted by slappy on December 28, 2008 at 13:27:38 from (65.0.132.140):
In Reply to: Bearings on MV posted by Mark in Mo1 on December 28, 2008 at 12:03:38:
I"ve not seen the SM setup but I believe it is the same as on the M. The M manual suggests that you clean and grease the bearings while still on the spindle - but I understand that you might want it off to better inspect its condition. You might try putting a bearing separator on the back-side of the bearing and then use your puller. Also the fit might be such that a punch or drift on the inner race will let you tap it off without damage. Yes, the bearings are available, but they might be a bit pricey depending on where you buy them.
Good Luck,
