100 hydraulic oil filter screen has a hole
Posted by couv on December 28, 2008 at 16:58:46 from (209.33.29.2):
What's a good source for the brass hydraulic oil filter screen for my 100 ? # 354355R91 Strainer ?
Mine has a hole in it, about the size of a quarter. If I wouldn't know better, I'ld say a mouse chewed on it.
I'm bringing the touch control block to a local mechanic to finish the tear down & cleaning. I couldn't get some of the allen plugs out. The one I did remove had some oil-mud gunk beneath it.
Would you use a "used" screen or go new ?
