Re: 3-Point for Super C
Posted by Hugh MacKay on December 28, 2008 at 18:34:57 from (209.226.247.103):
In Reply to: 3-Point for Super C posted by Smith1000 on December 28, 2008 at 06:11:50:
Smith: The Saginaw hitch with the remote valve and cylinder is good value for your money, Worksaver is not. You can build a much better smilar type hitch to a Worksaver, for a fraction of the cost of a Worksaver. You will not build Saginaw quality for less money than a Saginaw.
Worksaver will lift about 350 Lbs. at hitch pins. Using proper geometry you can build one to lift 650 lbs. at hitch pins. The Saginaw will be limited only by front end weight and will lift about 1,200 lbs.
