Re: I.H. 300 utility steering box problem
Posted by Dellbertt on December 29, 2008 at 06:12:08 from (209.172.22.46):
In Reply to: I.H. 300 utility steering box problem posted by Charles Tolbert on December 25, 2008 at 19:41:22:
I checked back on the IH parts page and the 11" pitman arm is the same for with PS and without PS. Same part number.
So I for sure would use the 11" arms an your fix.
Once you get a good parts pictorial for your tractor you'll be all set.
Dell
