Re: h rear wheel adjustment
Posted by glennster on December 29, 2008 at 15:50:59 from (68.60.242.156):
In Reply to: Re: h rear wheel adjustment posted by LM on December 29, 2008 at 15:10:08:
like georgeky said, not a bad job to turn the wheels. take a can of penetrating oil or an oil can to lube the axle shaft a litte, or some grease, makes em slide easier. WORD OF CAUTION...check to see if the tires are loaded with calcium chloride liquid, if they are they are very heavy!!!!!! with the valve stem down, press it a little and see if just air comes out, if so...ok, if you get fluid....be careful!!!! could have up to 500 lbs of chloride in the tire, plus the cast center, figure couple hundred pounds, plus the tire and wheel, maybe 800- 1000 lbs. could have wheel weight too, them are about 140 lbs a piece. you may only need to flip one wheel to get in narrow enough.
