Had a simular problem with an M last winter. Pilot bearing was bad on transmission input shaft and a bearing went inbetween 2 gears. Take the gas tank off than remove belt pulley assy. if you have one or cover plate if no belt pulley assy. You might be able to reach into that compartment and see if you con move the input shaft. Keep in mind that my experence is with a M but a H should be about the same. You need to get a I&T repair manual so you can get an idea of what you are dealing with and how to do it. To pull the top cover from the transmission the cover needs to be lifted as level as possible to prevent the cover from binding on the pilot bolts. If it is the pilot bearing you will have to split the tractor behind the hyd. pump. Also keep mind that I found a piece of bearing in the compartment under the belt pulley assy. so clean every compartment before putting everything back togather. Keep us posted as to what you find. Armand
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
