Re: C-123 scary start after rebuild
Posted by steelfronts on December 29, 2008 at 18:29:10 from (66.227.243.0):
In Reply to: C-123 scary start after rebuild posted by DRC on December 28, 2008 at 07:30:53:
Having read all the other posts I'll tell my story on a WK40. Complete rebuild.Tractor isnt elec start so had to crank start it. Six cylinders are hard to crank so things had to be right to start.Finished it up and went to plowing. Used it several times had twenty or so hours on it but never shut it off unless I was done with it for the day. Then I did shut it off and tried to start it within 15 minutes later.It was stuck.An hour later spun over and started right up and ran good with good oil pressure. Anyway it had to sit for about an hour after running it to start it or it was tight. I had to take the pan back off and find the tight bearing . One rod hadnt been reconditioned.That was the fix. souns like yours is doing the same thing.
