Re: Farmall HTA
Posted by D Slater on December 30, 2008 at 06:14:09 from (71.164.59.34):
In Reply to: Re: Farmall HTA posted by Fred Goodrich on December 30, 2008 at 04:51:55:
Anything is posiable, but think your going to find a non IH built one. Ones that are done nice use a early 300 transmission and T/A unit. Shift forks are modified so that the SH transmission cover will work. Little work done at T/A housing to make SH hydraulic unit mount. All other parts used from a stage 2 SH. Real looking serial tag for SHTA made up along with decals. If they don't change casting date codes or grind off, the only thing that gives it away is later in year 54 date codes than normal for a 54 SH on transmission, T/A housing ETC. Some are also made with parts that are easy to tell.
