Most times on that type seat the hole that piviot pin goes through in pipe is worn or broken. Fixed several by making a new pin and some welding. If you unbolt bracket from transmission cover and turn seat upside down you can see problem. Or move seat side to side bolted on tractor and you can see pipe roll in bracket some. If hole through pipe or bracket is very bad you can remove old material and weld a steel bushing into pipe with correct ID for pin. If holes are worn in holding bracket use bushing for oversize pin. If nothing is worn to bad just a oversize piviot pin with holes enlarged to match will work. Be sure to get hole in pipe centered or seat will lean. Also if no worries about removing again the piviot pin can be welded at ends on bracket and ground down smooth.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
