Re: O/T Avery Model A Help
Posted by rhettcale on December 30, 2008 at 10:42:07 from (70.194.147.114):
In Reply to: O/T Avery Model A Help posted by chad504 on December 30, 2008 at 10:21:01:
engine most likely is an IXB 3 machine seriel number should be stamped in the top plate of the right framerail, mine was at the very rear it took me 2 days of removing paint to find it. the engine nameplate should be on the right side, just abofe the oil pan in front of the clutch housing. theres info on this site for dating the machine with the SN. im currently working on one also, same situation. had sat for a long time and was seized up. i had penetrating oil in the cylinders for a month to no avail, i removed the engine and put it on a stand, turned it over and pulled the oil pan off, ive been soaking the underside of the pistons with penetrating oil. i may be moving tword more drastic measures in the coming weeks. its good to know im not the only one working on one.
