Posted by A J on December 30, 2008 at 15:24:22 from (71.74.115.57):
In Reply to: Farmall H backfiring posted by Gregg Anderson on December 30, 2008 at 13:52:06:
If you feel comfortable that you have ruled out all things electrical & ensured that it is timed correctly, check the following: Distributor gear, Compression check of each cylinder, then with the motor running - remove valve covers - ensure proper functioning of valve springs & push rods. You might find the problem here in the top end of the motor - and need an overhaul............
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
