Cotton picker tractors often had the big single wheel. I owned an MD with a single. Mine was a 750 10" which made the standard MD level front to back. Cotton picker Serial suffex was often X20 on the serial tag, but that is not a certainty. Rear axle housing flanges were also often very different. some were made to operate in reverse with a trans top and shifter relocated and the differential flipped to run backwards. Good luck. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
