Re: MDV w/ single front wheel
Posted by Harold H on December 30, 2008 at 17:29:12 from (69.40.17.4):
In Reply to: Re: MDV w/ single front wheel posted by Ellis Aakre on December 30, 2008 at 16:26:37:
Ellis,
If the serial plate says MDV somebody has swapped the original high wide front axle for the single fork from a high drum picker tractor which originally had a 750 x 20 single tire. High wide front was only front end available from factory on MDV although cotton picker single wheel will bolt right up. The drop housings on cotton picker tractors were bull gears whereas drop housings on MDV were chain drives. The high cotton pickers did not have two gearshift holes on the transmission top. However if your tractor is a high drum cotton picker tractor, and runs forward, it will have the transmission top ftom a low drum cotton picker tractor, which has two holes, in order to make it run forward.
Harold H
