Re: 200 touch control chirps jumps
Posted by Larry in MO on December 30, 2008 at 18:52:28 from (75.105.154.153):
In Reply to: 200 touch control chirps jumps posted by couv on December 30, 2008 at 17:50:57:
As always, check fluid level and filter. The filter is a metal screen that comes out where the temp sender goes in(4 bolts). Other than that the only thing that makes mine do that is movement of the steering support. I'm always grabbing my steering wheel to get om and off and even when the bracket is tight it will flex enough to change the setting. Make sure that support is good and tight as you may be looking side to side or to the rear and putting pressure on the steering wheel. LE
