The oil pump plate on my c-123 engine was warped too bad to remove the warpage by sanding. Check it with a straight edge, If it is bad off take it to your local machinist they can mill it flat again for around 20.00.When reassembling check the clearance of the gears in the pump they should be : 0.005-0.008, Use new gaskets on the end plate and add or remove gaskets to obtain a "cover to gear" clearance of 0.0035-0.006. If you still have poor oil pressure it is probably due to worn main and rod bearings.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
