Re: Super-MTA
Posted by GeneMO on December 31, 2008 at 13:05:53 from (216.74.221.122):
In Reply to: Super-MTA posted by Red Iowa on December 31, 2008 at 09:18:43:
I scanned page 31 of the manual which is the lube chart, but cannot figure out how to post it.
It says the lift-all should have "IH Touch Control fluid" Whatever that is. I am betting it is close to hy-tran. 7 quarts.
The transmission and differential case takes 15 gallons of SAE 80.
The engine holds 8 quarts of SAE 30 if the temp is above 80. SAE 20 from 80 degrees down to +32 degrees F. and below +32, SAE 10.
Again this is all out of the owners manual.
Good luck, Gene
