Your tractor only has TWO hydraulic ports. One of the front ports is also connected to the rear ports, and is controlled at the same time by the same lever. If you had three ports you'd have three levers to the right of the seat.
I believe the left front ports and the rear ports are the ones connected together.
Normally, you would run the lift cylinders with the left ports (and left lever), and the bucket with the right ports (and right lever).
The problem is the single acting cylinders on the lift. Your 706's hydraulics are two-way only. If you try to use the normal up-down controls, you will stress the hydraulic pump and eventually burn it up on the down side unless you are careful to always use the float function to lower the loader.
The lift cylinders probably can't be converted to two-way, and replacement two-way cylinders will cost more than you paid for the whole loader.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
