Posted by Hugh MacKay on January 01, 2009 at 14:02:43 from (209.226.106.61):
In Reply to: Seasonal disconnect posted by Steve SW Pa on January 01, 2009 at 13:49:49:
Steve: Two reasons, back in 1954 it was no point in turning IPTO, at time when it was not in use. Secondly the tractor started easier in cold weather.
We used to disconnect it on our Farmall 300 in Nov, and not recouple it until June. If we needed PTO, it was only 5 min. to couple it up. If cold weather we'd warm the tractor up than shut it down for coupling. It makes quite a difference starting when temperature is below 0, F.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
