Re: Farmall M 12v conversion problems
Posted by Janicholson on January 01, 2009 at 14:39:11 from (66.173.50.32):
In Reply to: Farmall M 12v conversion problems posted by tcanthonyii on January 01, 2009 at 14:27:21:
The alternator needs to be all the way towards the valve cover. A secondary adjuster on the outside belt run, pulling outward, is best. THe original IH bracket can be turned upside down to gain the vertical clearance. (it is possible to use the Alt as an adjuster, but the belt needs to be put on as the alternator is put into the lower pivot, not when in place.) Sure, the tractor can be run W/O the charging system. Negative ground, Take the bulbs out of the lights (need to any way). No issue other than keeping things out of the belts and fan. JimN
