Posted by charles todd on January 01, 2009 at 16:34:50 from (205.242.95.141):
In Reply to: OT Drilling Concrete posted by GordoSD on January 01, 2009 at 07:19:22:
I read the first post but was unsure if you are using a conventional drill or a hammer drill. Concrete bits are only designed to work in a hammer drill. They will last a long time if used properly in a hammer drill. A conventional drill will burn the bit up shortly regardless of speed due to constant friction. The hammer action breaks up the concrete as it drill. There are Masonary bits that are for convetional drills for drilling block, brick, or morter only! Try to drill cured concrete with a masonary bit and likley it will dull before the hole is finished. Star drills are still available but why? They are slow and well, slow. Find a friend that has a hammer drill before you decide to star bit. I have drilled A LOT of holes in concrete. A true hammer drill bit used in a hammer drill should last 50 + holes through concrete, wire, rebar, aggergrate, ect.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
