Re: Farmall M 12v conversion problems
Posted by mdaitc on January 01, 2009 at 16:39:05 from (70.194.131.109):
In Reply to: Farmall M 12v conversion problems posted by tcanthonyii on January 01, 2009 at 14:27:21:
it might not help at this stage, but i just converted my 330U to 12V -ve ground, and found that an "Ultima 14231" alternator (from my local Oreilly autoparts), was the same width (but shorter) than the original generator, and that i could use it directly without making any brackets or modifying hoods.
Had friends who converted their 350U with the "standard" GM 1-wire alternator and had to make the bracket, and modify hoods.
The Ultima 14231 is off a 78-79 Nissan 620 Pickup. go figure. it wasn't that much more expensive.
I found this alternator after reading a post here on YT with someone doing something similar, can't seem to find it at the moment.
hope this helps,
