Re: Bar's Leak Head Gasket Repair
Posted by Janicholson on January 01, 2009 at 17:53:53 from (64.83.200.187):
In Reply to: Bar's Leak Head Gasket Repair posted by SDE on January 01, 2009 at 15:37:56:
Two issues are involved. The first is that .004 is OK. Many seal when flat to the deck. So the leak needs to be analized to assess where it is leaking. A compression/combustion leak to coolant cannot be sealed with a sealing product. If your engine is leaking coolant into a combustion chamber, I believe it will probably not be fixable that way. If it is leaking coolant to the outside, then do it. My experience is favorable to that solution. Please describe your coolant loss so a better handle can be attached to the problem. If an air hose was attached to the #4 cylinder sparkplug hole, and 100psi were put in the cylinder (both valves closed)(roockers removed, or adjusted closed) where would the pressure go? JimN
