Re: Moving 1256 wheels
Posted by Lee in Iowa on January 01, 2009 at 19:23:06 from (66.172.198.9):
In Reply to: Moving 1256 wheels posted by Baelee05 on January 01, 2009 at 11:41:31:
I used to move mine every year for a mounted corn picker. If you get lucky and the outside wedge comes loose first go ahead and turn the bolt all the way out of the inside wedge and turn the wheel so the wedge is on the bottom. Then take a large punch, I use an old axle one inch diameter and about three feet long, put it against the inside wedge careful not to damage the threads and hit it with a maul. Knock the wedge out move your wheel and reasemble. If you don't get lucky and the inside wedge comes loose first then you have to use the horseshoe thing. In my experience the outside wedge comes loose first 90 % of the time and I've never had an axle bearing go out from knocking the wedge out. If you move them there's a procedure in the owners manual for tightening them and its a good thing to follow it even then they work loose sometimes so check them a lot. Lee
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
