Re: Installing a V-8 in a Farmall?
Posted by charles todd on January 01, 2009 at 20:14:53 from (205.242.95.141):
In Reply to: Installing a V-8 in a Farmall? posted by Jesse Kasper on December 31, 2008 at 23:44:39:
I have seen this come up before... People have posted asking about a SB IH V-8 as well as SB Chevy's and Ford's. If you had the stock for a motor plate (3/8" plate???) you could drill the dowel holes then use transfer centers (threaded studs with a centering point for transfering holes) and then take this to a machine shop. After the holes are match drilled then you could cut out the waste from the center with and jigsaw, vertical mill, ect. Good luck.
Charles
