Re: I.H. 300 utility steering box problem
Posted by Glen,Iowa on January 01, 2009 at 20:57:53 from (4.226.237.120):
In Reply to: I.H. 300 utility steering box problem posted by Charles Tolbert on December 25, 2008 at 19:41:22:
Interesting I just did my 300 steering this past summer. My manual steering was very difficult. I ended up putting two matching cylinders attached to the steering link arms. Orbital motor above steering gear box and it works great. But all their is in the box are two different shafts coming from right and the left side both are different in length and each have a barbarick type gear that would make anybody grunt when they would go to turn the wheel. I removed the entire steering shaft that was attached by the worm gear. Then when the cylinders on each side would push and pull the shafts and then gears inside the box would work with each other. I did it myself and don't have 1,200 or 2,000 in it only about 300 to 400 bucks
