Re: 460 Oil Cooler?
Posted by Janicholson on January 02, 2009 at 07:50:33 from (64.83.200.187):
In Reply to: 460 Oil Cooler? posted by John Athey on January 01, 2009 at 20:18:34:
one can be added it requires a pump to direct oil to the exchanger, and fittings in the pan to access the oil, and return it. Water cooled gasoline engines working with todays great oils do not need coolers in general. A percentage of engines are designed to use them due to other cooling limitations, but it is rare. If modifications were made to an engine to pump out 20% more continuous (field work, or PTO load) I would consider doing a cooler. At the temps that modern multi wt. oils get thin, or degrade from heat, the engine is already toast. JimN
